xtra sub?
Discussion in 'Subwoofers' started by micks_address, Feb 6, 2002.
  1. micks_address
    micks_address
    Nov 29, 2001
    4,635
    83
    Dublin
    +234
    Hi folks,
    I have a Sony HTK475 sound system. Its probably not up there in terms of high quality systems but the question I have is would it be worth adding a second sub woofer to the system. Looking at the sub it has a line out which I presume I could use to connect another sub. Does anyone know if this is possible or if the overall effect would be worth it?.
    Any advice appreciated.
    Thanks,
    Mick
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,462
    United Kingdom
    +1,918
    Two subs are better than one and will spread the bass more evenly. Not sure about the line out on your sub though!
    You´d be better off getting a Y connector instead and take the the 2nd sub off this.
    cheers
