What is the forum's thought on extended warrenty for Plasma's.
Generally?
I have found that most electrical items tend to be either DOA or break within the first few months if there is a manufacturing fault. So normally the manufacturers 1year is fine.
+1 years is usually down to wear and tear.
What is the minimum expected lifetime on Plasma parts? I bet nobody can answer this one. Anyone repaired one ? I've never seen inside one so I'm unsure on how much can be repaired in house and how much manufacterer only.
Are business models designed to last longer than home ones ?
When the price of some of the warranty's are as much as 33% of the cost price I have to ask is it worth it ?
There is no right/wrong answer. Its worth it if it breaks and you dont get a bill for £1000's.
Its a lot to pay for peace of mind.
Generally if the repair bill is > than the current value of the item you get the current value not a new screen. This may vary between contracts and the cost of the warranty.
I'm curious of what others have done and their thoughts.
Briggsy
Generally?
Briggsy
