XS32 IR Timings
Discussion in 'Blu-ray & DVD Players & Recorders' started by AVFan7667, Dec 27, 2004.
  1. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    Is it posssible to change the timings (specifically the gap between) of the numbers sent out to change the STB channel?
    Although I have no real prolems with it changing my STB channel, the gap between digits when it sends them is quite long, and on the occasions I have actually seen the change being made it looks like it is only just making it before the STB times-out.
    Someone told me that some DVDRs and PVRs have this ability but I can't find anything in the manual (unless I have blatently overlooked it) about it.
  2. JayCee
    JayCee
    Jan 20, 2004
    22,199
    Lanarkshire
    +2,313
    No, you have no control over that at all, what STB are yiu using?
  3. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    It's a Telewest Digital STB.
    It needs the Red-Eye to work (www.redremote.co.uk) and this has a special XS32 compatibility mode, but it doesn't work well in that mode for some reason (that the manufacturer has yet to figure out).
    In non-XS32 mode it works fine but the timings seem quite slow that are sent out from the XS32 and I can't help but think that 'may' be too sow one day.
