Hi All,
Well after a week of deliberation, my XS32 came today and even after just 2 hours I am well impressed. I just have one problem (at the moment) ...
I have a 32ZP48 so have connected up the XS32 with component cables, analogue audio pair & digital coax. My Sky box is connected the the XS32 via a scart to AV2. I also actually have a cheap & nasty scart from Sky straight to the TV on Ext1 but rarely use it.
Please assume everything from now on is viewed using the Ext4 component input on the TV.
Watching DVD's looks & sounds amazing so no problems there, also the onscreen menus from the XS32 are rock solid so I'm sure the problem I have with the Sky picture stems from the Sky to XS32 link.
When viewing the typical sky menus using the AV2 input selection (blue text on yellow backgrounds), there is a shimmering blue checkerboard pattern right above each letter, added to this the whole picture is shimmering. You have to get close to really see the effect above the text but its there. Most annoyingly it doesnt show if I view the Sky directly on the TV using its scart.
I have the AV2 on the XS32 setup as video, as the S-video setting produces a black & white shimmering picture, and the RGB setting produces a black screen. I have messed with the Sky video output, trying PAL & RGB and neither helps the situation.
Can anyone help, I would have thought if is select RGB (which I assume would be the best picture) on both units, I should get something other than a black screen ??
David
David
