XS32 - DVD Compatible Mode
Discussion in 'Blu-ray & DVD Players & Recorders' started by AVFan7667, Dec 20, 2004.
  1. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    Sorry if I keep coming on here and asking questions, but I am just getting to grips with my XS32 and the whole DVDR thing!
    As I understand it, if I want to transfer something to DVD-R (or -RW) then it must be recorded with DVD Compatible Mode On (Mode I or II).
    What does this do exactly? It says it records sound only from one channel - doesn't this mean there is a loss of quality
    I have read the manual but it doesn't explain entirely beyond this.
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Yes, I was confused by the same thing.
    As I understand it, this has to do with multiple language support. E.g. it is possible in a stereo brodcast (possibly NICAM only?) to broadcast say English on one channel and French on the other, rather than a stereo English broadcast. In this case you need to choose which channel (i.e. which language) you want.
    In practice, I don't think this is used, so even if you don't set this you can still create a DVD-R/RW.
    Still, I have mine set to Mode I, which means should this happen I'd get the "main" language (English).
    On everything I've recorded I've got stereo English; there is no problem with quality.
    I asked Toshiba about this, and all they could tell me is that it had something to do with multiple languages, they said set it to Mode I, and if found I was getting the wrong language try Mode II.
    Mark
  3. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    Thank you
    I set mine to Mode I but just wasn't sure if I was going to be losing anything by doing it.
