XS32 Connectivity Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by New Bloke, Jan 5, 2005.
  1. New Bloke
    New Bloke
    Oct 3, 2002
    334
    28
    Aberdeen
    +24
    I purchased XS32 rather than buying Sky+ as it is more flexible for my needs.
    One question which has not been covered is specifically down to connectivity.
    I have connected my Sky box to AV2, the settings for RGB and the Tosh is set up for AV2 RGB input.
    AV1 is connected to my Tosh TV (Picture Frame) and also by Component to AV4 on the TV.
    I have used two QED fully wired SCART cables, which were not cheap and when I view the Sky menus, they are of a poorer quality than connecting Sky direct to the TV. Same quality when I switched the XS32 off and view the picture through "SATMON".
    The general picture quality is excellent but this is just one niggling thing I would like answered.
    Any suggestions?
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    You seem to have connected everything correctly. The usual things to watch out for with Sky are
    a) Connect to the Digibox "TV" scart for RGB (not the "VCR" scart)
    b) Don't use the TV button on the Sky remote as this switches OFF the Sky RGB output (restore by pressing the Sky button)
    The SatMon button should simply passthrough the Sky signals to the television and the results should be exactly the same as if the digibox were connected directly to the television.
  3. New Bloke
    New Bloke
    Oct 3, 2002
    334
    28
    Aberdeen
    +24
    Oops, it's amazing how the small things can be overlooked, all sorted now :clap:
  4. New Bloke
    New Bloke
    Oct 3, 2002
    334
    28
    Aberdeen
    +24
    Okay, now the next stage.
    I have connected the XS32 to the TV on AV1 with RGB SCART and AV4 with Video Component and Optical.
    When I switch to AV4 (Component) now that the recorder is setup for RGB I get a blank (blue) screen. As there is options for AV2 input and AV1 output, I can't see any options for the component output?!?!
    Is there an advantage having the component connected or shall I disconnect and re-assign the digital audio to AV1?
  5. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    For some strange reason you have to set the XS32 AV1 to "Video" (or "S-Video") to get component output to work.
    Setting it to RGB output will disable component. My Panasonic E55 does the same. :confused:
  6. New Bloke
    New Bloke
    Oct 3, 2002
    334
    28
    Aberdeen
    +24
    Currently I have a set of 75 Ohm IXOS component cables and a QED SCART cable.
    Is it worth keeping both and changing the menu setting whenever I need to watch a DVD through component or just use the SCART cable?
  7. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    Depends how big the difference in quality is between RGB and component. This seems to vary quite a bit depending largely on the TV in question, so I would just experiment a bit with some good pre-recorded DVDs to see If you really notice much difference. :)
