XPC Shuttle advice needed
Discussion in 'Desktop & Laptop Computers Forum' started by hornydragon, Jun 11, 2003.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I am thinking of building a shuttle XPC type machine for a mate's GF and for me to have as a second PC after a year.
    Can you give some advice on where and what to buy.
    I am thinking of either an SV25 (cheap but 1Ghz Max) or an SK41G, It relly needs to be one that will take a floppy drive but i want to do it for minimal cost I would appreciate any help you can give me I have a 3.5GB HD drive to start it off:eek: :laugh:
    Seriously looking at dabs £250 seems to be the sort of price for an SV25 with HD mem CPU CDRW. and £300 for a SK41G with Duron mem HDD et etc but unfortunatley my inability to get a job means my current budget of £0 is not getting me very far!!!!!
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,523
    3
    Aldershot, Hampshire
    +286
  3. Jimmysil
    Jimmysil
    hornydragon
    I have the SK41G and it will take a floppy.
    The only problem is that the SK41G barebones will cost you around £200.
    As hawklord said, overclokers is a good place to get a shuttle.
    Thats where I got mine.
    The 3.5 GB hard drive should be fine in the shuttle.
    But how about something like this if you are on a budget.
    http://www.overclockers.co.uk/acatalog/Online_Catalogue_Asus_101.html
    Not as good as the shuttles, but cheaper
    Jimmysil
  4. Loafer316
    Loafer316
    Apr 8, 2003
    330
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Thanks guys i subscirbed to the thread but got no emails. The silver cuteness of the Shuttle is a big plus for me. I noticed an E cube in PCworld that has a curved handle on the top. Cant find it on the web thoughhave found the shutlle SK41G for £150 and the SV25 for £130 i am quite tempeted by the VIA chip as they are very cool running.
    Does the SK41G come with CPU cooling, I wasn't sure or do you need to buy a heat sink as well?
  6. Jimmysil
    Jimmysil
    Yes it does.
    I has a special vapour pipe cooling system that takes heat from the cpu via the little pipes and the heat in the pipes gets blow out the back of the case by a quiet fan.
    Infact its one of the selling points of the Shuttle.
    Regards
    Jimmysil
  7. Jimmysil
    Jimmysil
    The CPU cooling system looks like this
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Cheers Jimmysil I thought so but wasnt sure and the local shops i tried have no idea really...Has anyone tried the E-cube??? Can't find it on the web but think i saw it in PC world of all places!
  9. moid
    moid
    May 9, 2003
    40
    Leeds - UK
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Very nice mate but well out of my league the choice of a shuttle is that for £150 you dont get much more in terms of basic cases £30ish Mboard £50 ish add a cooler and a couple of other bits and a beige box is £120+ I'd go the extra £30 for the cuteness of a shuttle!!!
