XP Pro or XP home?
Discussion in 'Desktop & Laptop Computers Forum' started by zAndy1, Aug 24, 2004.
  1. zAndy1
    zAndy1
    Nov 26, 2002
    22,001
    2
    5
    163
    +8,432
    Is there any advantage to using XP Pro on a HTPC instead of XP Home? Going to get an OEM copy but Pro is quite a bit more expensive so I'll get home as long as there aren't any disadvantages to that. Also is it worth getting it with SP2 or are there issues with that?
    Andy
  2. sapper
    sapper
    Jul 20, 2000
    2,232
    Southgate, North London
    +141
    As far as I understand, XP-professional has more bangs and whistles, esp if youpaln on networking your home PC's.
    I currently have XP-home on my network but i will probablu upgrade.
    from talking to the chaps in IT here at work, if youcan afford XP-pro, gofor it
    Adrian
  3. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    The two major differences is that XP Pro has IIS built in (if you want to host an ASP based web site) and it can connect to a domain (not an issue unless you have some serious equipment at home).
    Other than that there is not a lot in it. ;)
  4. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    xp pro also has remote control which can be handy for htpc's.
    CaM
  5. pinkerton
    pinkerton
    Sep 26, 2002
    416
    Ealing (London)
    +3
    All the above is correct but also XP Pro is compatable with dual processor systems.
  6. Lostinapc
    Lostinapc
    Go for XP Home, I have XP Pro and it was a waste of money!
