Xp Mce Codec problems
Discussion in 'Microsoft Windows' started by dazzer123, Feb 2, 2005.
  1. dazzer123
    dazzer123
    Sep 30, 2002
    402
    Stoke-On-Trent
    +3
    I am trying to get my Mce setup running correctly and am having a few problem's mainly in Media Center when tryig to view Tv or Playback Dvd i get sound and no picture.
    I have downloaded Microsofts Decchek utility and i have Nvidia,Cyberlink and Intervideo codecs installed and are all Mce compatible and have tried setting all of them as the prefered codec for Media Center but i still can not get a picture would anybody have any idea what could be causing this.
    AMD XP 3200+
    ASUS ATI 9550
    512MB DDR 400
    200 Gig Maxtor
    Pioneer 109
    Windows Xp Mce
  2. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    I had a similar problem - no dvd playback, but because I had no codecs installed - so I closed down media centre to get the normal XP desktop and played a dvd through mediaplayer. Because no codecs were installed it pointed me to M$ website where I downloaded and installed the nvidia codecs.
    It may be worth trying to play a dvd through mediaplayer in this way because if it works then you know mediaplayer is ok and that it's something in MCE that's causing the problems.
  3. Rambles
    Rambles
    Jul 14, 2004
    8,305
    UK
    +1,281
    MCE2005 is really ssy about codecs, I had loads of problems in this area, and the only way I got it working properly was to do a clean install and keep codec installations and all installations as minimal as possible, I think 'vanilla' is the term.
    I currently (fingers crossed) have MCE2005 running flawlessly and playing back all video files in very high quality using this combination of codecs...
    Cyberlink PowerDVD 6
    AC3 filter
    Xvid only codec
    And No OTHER CODECS!
    Cyberlink has Divx codecs included
    hope this helps
  4. dazzer123
    dazzer123
    Sep 30, 2002
    402
    Stoke-On-Trent
    +3
    Cheers after banging my head repeatedly off the wall I decided to update my graphics card drivers and guess what problem solved I presumed that as the Operating system accepted the original drivers that they would be Mce compatible how wrong I was.
  5. Derek22
    Derek22
    Jan 25, 2005
    246
    +18
    dazzer
    any chance you could post a link to that decchek utility, or is it part of the os. I found the latest carylst drivers solved my problem but before I found that solution I tried both power dvd software and intervideo software and would like to see which one mce is using before doing a fresh install.
    ta
  6. dazzer123
    dazzer123
    Sep 30, 2002
    402
    Stoke-On-Trent
    +3
  7. Derek22
    Derek22
    Jan 25, 2005
    246
    +18
    thanks for that usefull tool.
