XP MCE 2005 Installation...
Discussion in 'Microsoft Windows' started by Waynej, Sep 19, 2005.
  1. Waynej
    Waynej
    Oct 4, 2004
    7,204
    Wales
    +1,076
    Hey, just wondering as I'm wanting to buy mce 2005, is this an add on to your current XP os? like I have XP Pro setup now so would i just put the mce cd's in and install or is it a new OS that has XP features on it?
    Thanks for any help, sorry for sounding dumb, can't help myself :rolleyes:
  2. Cyclone
    Cyclone
    May 23, 2005
    404
    28
    +44
    MCE 2005 is a complete OS, so once installed it gives you Win XP Pro (minus some of the advance network options-someone correct me if i'm wrong), then once you boot into XP you can run the Media Center front end (or run it at startup).
  3. thefair1973
    thefair1973
    Jun 28, 2005
    105
    Hertford
    +3
    MCE2005 is a full-blown version of Windows XP + SP2, but comes with a 2nd CD of add-ons. The additional installation of the MCE add-ons is enabled via your product key. Also, the networking features are all there, apart from teh ability to join your PC to a domain. This can be attempted during setup, but if you skip it, the only way to join a domain is to re-install.
