Hi, I`m looking for recommendations please for an XP laptop [ no Vista, no Win7, dont like `em, dont want `em, wont use `em, so please dont try persuading me as I will just get the glazed eye`s jobby
My current lappy is a prehistoric ASUS which has bare minimum software on it as the thing is full, often showing less than 200mb of space no matter what I delete from the wretched thing and I have no idea how to repartition it to use the near empty D drive space
and software refuses to load or work on D Drive so thats an utter waste [ just who designs these things to be so un-user friendly for non-techie clueless people like me
Primary use for a new one is for photo processing and occasional gaming of fairly low spec disc games. I will probably keep using current lappy mainly for internet and printing as I`m a technophobe and can`t be doing with messing about re-loading any more software than absolutely necessary [ ok, ok, I don`t know where on earth I put most of my software discs
], so basically I need current one for lower spec usage and new one for decent speed higher spec stuff.
This one I found is not a lappy but wondered if anyone has it or could tell me if it could handle what I need it to do ?
EMACHINES EZ1601-01 buy online | Currys
I`m confused about the ram side of things, I upped current lappy from a paltry 512 by adding a gig [?] to one of the slots as it doesnt have to have the same in both and I did`nt have money to waste on both slots if better speed was`nt going to be noticeable [ it was a bit better as it happened ], so in theory I have more than the 1g lappys for sale so would they be slower than my prehistoric lappy ??
Current spec is
Screen size 15.4 inch [ would`nt want to go smaller ]
A6U
Mobile AMD Sempron
Processor 3000+
197 MHz, 1.12GB of RAM
Local Disc C
File system FAT32
Free space 326mb [ which will drop to under 200 if I breath too hard near it ]
Total size 32.4GB
Local Disc D
File system FAT32
Free Space 21.0GB
Total size 21.5GB [ flippin` frustrating not to be able to blimmin` use it on C instead
Current `bits` running from it are a printer, external re-writer, 2 x eternal hard drives, multi card reader via usb, mouse and keyboard [ can`t stand built in keyboard and annoying little pad thing
New one will just need to cope with my photo editing programs, a few games [ all which did run on current lappy til I ran out of space so had to delete them darn it ! ], keyboard and mouse, external re-writer unless a built in one actually works properly
and / or external HD for photo storage plus usb card reader if new lappy does`nt have SD slot or cant cope with sdhc cards [ current lappy can`t deal with them anyway but can cope with basic sd card ].
New one does`nt need to look sleek and swish [ just need it to work properly, not to pose with
] nor be lightweight as it will be a permanent fixture like a normal computer would be.
I know I could ask in shops but so far have always found salesmen pefer talking about stuff that goes right over my head like its a sport to them, or going on about systems I have to repeatedly tell them I definitely DONT want but they still try to sell me what they want to use themselves instead of what I actually need
Well dont if you`ve stayed awake so far, hopefully my lack of technical knowledge shines through to explain why I would appreciate recommendations on specific models which would suit.
Current spec is
A6U
Mobile AMD Sempron
Processor 3000+
Local Disc C
File system FAT32
Total size 32.4GB
Local Disc D
File system FAT32
Free Space 21.0GB
