XP home to XP PRO upgrade
Discussion in 'Desktop & Laptop Computers Forum' started by schillaci0, Jul 21, 2005.
  1. schillaci0
    schillaci0
    Jan 18, 2005
    670
    Starting to get where I want to be
    +14
    :hiya: Are upgrading xp home to pro do i just put the disc in and let it do it's work or do i have to remove home or something. Not really sure so any advice will be appreciated :thumbsup:
  2. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +100
    I think all OS upgrades in Windows allow you to run it as an upgrade to existing (Windows) OS, or as a fresh install. However, it always recommends you backup data beforehand. I have never done this, preferring to do a completely fresh install, allowing Windows to essentially reformat the drive and start again - of course, this is after moving all data to another HDD, or making backups to an external CD/DVD or USB drive. As you should make a back-up of all the data in any case, I would certainly go for the fresh install over the upgrade, as this will hopefully eliminate any potential hardware and software conflicts which may come up if Windows does not recognise things the way it should during the upgrade path. Every IT guy I have asked says the same. Just my 2c worth.
  3. mjn
    mjn
    May 24, 2001
    21,869
    Herts, England
    +9,545
    XP Home -> XP Pro, should not provide any software/hardware conflicts, as if you were upgrading from Win98 -> XP.
    The core of the OS is the same, and Pro just adds more features, such as being able to be part of a domain.
  4. shezzy2k
    shezzy2k
    Aug 17, 2004
    499
    28
    +26
    I would recommend a clean install after backing up your data. If your existing OS isn't as healthy as it could be which is highly possible with Windows, you may carry over those problems with the upgrade.
    Good luck with it!
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    you'll be surprised how fast the computer runs with a fresh install of windows over upgrading, its worth it!
  6. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    Hi guys,
    i really need help now so here goes.
    Attatched a external hard drive and backed up files using windows files and settings transfer utility in system tools to said drive.
    Done a complete fresh install of xp pro with formatting etc.
    Reattatched said drive to transfer back across but cannot open as they are all in a .dat file format. Looked on ms website but to no avail.
    Please help as i got over 107gb of files i can't get at.
    thanks in advance
  7. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +100
    Can you go to the same systems utility tool in XP Pro and transfer the data into the new OS by selecting the "this is the new computer" option?
  8. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    Yes and this is what i done but for some reason they won't open. I an beginning to be very peed off with xp and the lack of relevant help from the ms website they seem to just direct you to somewhere else. i call it passing the buck!!
  9. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    Still having no luck! anyone got some ideas?
  10. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Why did you use .dat? Why not just copy the files directly? I don't really trust those progs which back up for you.
    No idea on how to fix. Google perhaps?
  11. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    Hi chrislad,
    you see iam not really that experianced with computers but i know my way round a little, and i assumed if i use microsofts own file transfer wizard then i could'nt really go wrong. What do they say about assume "makes an ASS of U and ME". so there i am an " ass".
  12. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Ah well. Sh*t happens. Best bet is to google for some fixes, if MS aren't getting back to you. That or try some more specialised computer forums.
  13. HMHB
    HMHB
    Nov 11, 2001
    26,631
    Nottinghamshire
    +5,334
  14. schillaci0
    schillaci0
    Jan 18, 2005
    670
    +14
    Too late have deleted files and have started again. never mind eh only more time on microsofts crappy system
