XP file delete question
Discussion in 'Desktop & Laptop Computers Forum' started by Taz, Jan 19, 2003.
  1. Taz
    Taz
    I have an .AVI file sat on my desktop, nearly 1Gb in size that just wont delete. XP keeps telling me its in use by another program or by another user! I have closed every thing thats running and it still gives me the same error.
    Anyone have any tips for getting rid of it?
    Taz.
  2. Sgt.Colon
    Sgt.Colon
    I've had this problem loads of times. It's a real pain. Go into a program and then go to open a file. Go to your desktop and right click the file from within the program and choose delete. That shoud work :)
  3. Taz
    Taz
    Hmm.... that didn't work, the file is still in use it reckons!:mad:
    tried to do it through MS Word should that have done it?
    Oh! and the file isnt on the desktop its in my downloaded folder but that shouldn't matter should it?
    Taz.
  4. Sgt.Colon
    Sgt.Colon
    Right the other way to do it is to boot into DOS mode and then go into your downloads folder and use the del or deltree command. :)
    I have found that one of the biggest culprits for do this with AVI files is InCD.
    But DOS mode should do it. Not a command promt within windows but booting to DOS. :)
    Lets just hope you're not NTFS :D
  5. Taz
    Taz
    Well, its gone thank the lord!:D had to reboot, F8, safemode with command prompt and delete through DOS! Phew!
    Cheers for the replies
    Taz.
  6. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Was it anything... how shall we say... embarrasing? :D
