XP customize help please!
Discussion in 'Desktop & Laptop Computers Forum' started by Lex, May 16, 2002.
  1. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Hi all,
    I am currently running Windows XP and wish to customize the background pictures in some of my folders, but I cannot figure out how to do it!
    In Win98/me/2000 you simply right click and choose 'customize this folder' - then you modify background template. However, in XP it doesnt offer this option. Is there any way to do it, or is it just not possible under XP?
    I hate plain folders!! :mad:
    Any help would be really appreciated as I have tried searching loads of sites, but can't figure it out!
    Cheers,
    Lex.
  2. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    I am not sure that it can be done but have a look at this thread from google.
    http://groups.google.com/groups?hl=...e4&[email protected]#link1
    Some people say it can be done but I have not tried. I dont mind the plan old folders ;)
    Another person had wrote
    "You can't do that in XP
    But if you get StyleXP you can add themes from:
    http://www.themexp.org "
    I have used themexp before and it does change the look of windows quite a bit but i am not sure about inside forders.
    Download it and try a theme.
