Xover frequencies on Marantz SR5400?
Discussion in 'AV Receivers & Amplifiers' started by Falp, Aug 4, 2004.
Tags:
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Can anyone tell me what Xover frequencies are available on the Marantz SR5400?
    Thanks in advance!
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    And if it has independent Xover frequencies for each chanel please...
  3. jdanielp
    jdanielp
    Jun 20, 2002
    184
    22
    Edinburgh
    +3
    is variable/independant X-over a common feature on receivers these days? my sr5200 doesn't seem to have a choice of X-over so would like to get a new one which does when i upgrade... :lesson:
  4. Radiohead
    Radiohead
    Dec 24, 2001
    4,337
    Amazingstoke
    +431
    You'll be lucky - the new higher-end HK amps only just have these.
    AFAIK the 5400 is fixed at 100Hz.
  5. ajt
    ajt
    Jul 29, 2004
    24
    Just bought one of these from richersounds on eBay. Was advertised as having no remote or manual and being graded/ex demo. Came with remote and manual and looks brand new so I'm very happy.
    Anyway, reading the manual (I'm moving house so haven't set it up yet) crossover frequencies are 80, 100, 120 Hz. It also does some bass mix thing to control the mix between large front speakers and sub.
  6. dongagon
    dongagon
    Feb 7, 2003
    583
    Bedfordshire
    +7
    thats correct, the crossover can be set to those frequencies, however the individualy speaker crossovers cannot be set
  7. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Thanks guys! :thumbsup:
    I think I?ll wait for the SR5500 to have 40 and 60 Hz :confused:
