XLS200-DF MK2 rubber feet
AntzDj
I need to get some rubber inserts/feet for my XLS200-DF mk2 as the white inserts are no good on my wood floor. On big bangs or rumbles it vibrates on the floor a bit. If i sit on it, it's fine.
I emailed BK but no reply. Has anyone found some rubber solutions? I've looked around diy shops but no joy.
swiftpete
You could try getting some rubber door stoppers from wilcos or b & q and sitting it on them. That'd only cost you a couple of quid. If they're a bit hard, wilcos also sell the rubber feet that you put on the bottom of walking sticks, which are slightly softer rubber.
jb001e9634
I use these in my XLS200. Best of both worlds, isolation, but felt bottomed.
AntzDj
I found some rubber feet for walking sticks, but the feet on the sub are way too big. So i cut the shaft bit off the rubbers, flipped over the base (of the stick rubber) now very quiet. Sorted :)
Repton
Or try spikes with shoes, sorted:)
[/IMG]
AntzDj
Cool, I'll keep them in mind. My walking stick rubber bottoms do the job and look the same and at only £5 in total I'm happy.
Podcast: The Best TVs and Projectors of 2020, plus AV, TV Show & Movie News & Reviews
