XLS200 connection to Onkyo
toocan
which subwoofer RCA do i connect from my XLS200 to my onkyo 705? is it the mono on the XLS200 and the 'pre' subwoofer on the amp?
IronGiant
You need to connect the right hand channel of the low level input on the sub, (marked mono) to your amp.
Your Onkyo will have a sub out/LFE that will be clearly shown on a picture of the back panel in your manual. If you can't work out which it is, post up a picture from the manual, or the amp itself and we can help you from there.
Dave
toocan
ive lost the manual unfortunately hence the question. theres two subs rca connections one is classed as "pre" the other isnt which one would it be?
paulst10
Subwoofer pre-out :thumbsup:
The other is a multi ch sub input :)
