XLR connections to Phono
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by meoldchina, Jul 6, 2004.
  1. meoldchina
    meoldchina
    I need some info on the best way to connect my newly ordered ATC C2 system to my Denon 3802 amp. I will just be using this as a preAmp ...funds will not let me get the next up grade.
    I have XLR input to my Active speakers but Phono preouts from my Denon.
    What is the best solution?
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    I sent you a pm, did you see it?
    I'll repeat it anyway.
    I just had my dealer make up the leads I need, RCA to XLR in the lengths I wanted. Very easy to do. If you have nobody local or just need a contact, that dealer is www.signals.demon.co.uk
    It is also possible to buy RCA to XLR adaptors that you put onto normal RCA to RCA interconnects.
    I'll be interested in what you think of the sub in that package. 9" driver isn't it? Wondering how it'll perform.
  3. Family Guy
    Family Guy
    I had some Quad amps this time last year that XLR inputs. I went to a "disco" shop - you know, the sort of place that sells DJ equipment and the like - and they sold them already made up at £9.99 for 5 metre stereo lengths...not the best quality in the world, but did the job...I'll try and get the number for you if you're interested.
  4. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    I think Digital Village sell these
    John
