XLR bridge pins
Discussion in 'TAG McLaren Audio Owners' Forum' started by Thunder, Oct 6, 2004.
  1. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Just got hold of a pair of bargain MRs, but the pins are missing from the XLR inputs so Im loosing about 10db in gain. I will change over to XLR cables eventually but Id just like to get em running properly on single ended inputs to start with.Dont suppose anyone has got some spairs kicking around? :D
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,350
    Livingston, Scotland
    +227
    Thunder
    When I got my 250x3R the pins were missing so I used paper clips for a few days until my dealer got the pins to me. They worked well.
    Switching to the pins gave a more liquid sound, the quiet passages were inky black........ :D
  3. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Used heavy gauge cooker power cable last night, but couldnt get it to work. Have ordered some RCA to XLRs from Mark Grant, so hope to get em soon.
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Careful............
    Only use the correct diameter of shorting link otherwise you stand the risk of opening out the socket and an XLR pin won't grow to suit.......The correct diameter pin is 3/32" if anyone is interested.
  5. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Cheers Graham, the diam of the wire I used was actually too small, I have ordered some custom RCA to XLRs from Mark Grant and he reckons he can get em to me for the weekend :D
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Hope they are wired as per TAG's drawing on the subject, the connection of the screen at the right end is also a factor.....
  7. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Yep, Got Mark to download the 250MR manual with the connection diagram before he started to assemble them :)
