When in User mode, you should have a choice of color temperature: standard, cold, warm, and custom. In your screenshots I don't see 'custom' color temperature so my guess is that your model doesn't have the firmware update that enables that option.
Did you make sure that your pj is on the latest firmware?
If no custom option is available I'd suggest Warm as the next most accurate option which is closest to D65
Are there any differences in input lag on android 8.1.0 compared to the original OS that the projector was launched with?
(input lag can be tested and calculated by feeding a mirrored input through a secondary screen and capturing a photo of a running timer with ms indication using a camera that shows both screens - captured multiple times to average the results)
I was hoping for some improvement in that field with a software update, and I was wondering if that's the case.
Hi, do you know where you can buy this MJJGYY02FM version from?
Sorry, got mine in Hong Kong, the stores where i visited aren't doing any international shipping yet. But i'm sure they will be available in the near future.
I think that the people buying this want an ultra short throw projector instead of having to have their projector a few metres away to get a decent size picture and because it uses a longer lasting laser instead of a bulb.Why is this projector better than an Optoma or BenQ 4k projector? The price is the same. And the bright and contrast is worse.
Not to mention both 4K HDR and 3D playback availableI think that the people buying this want an ultra short throw projector instead of having to have their projector a few metres away to get a decent size picture and because it uses a longer lasting laser instead of a bulb.
Re the illusive MJJGYY02FM version
I've contacted Gearbest, they do not stock it, all their versions are the 01. I'm guessing the International version they sell is just the Chinese version with the APK installed!
Has anyone found a way to decrease fan speed or reduce fan noise by doing any external mods...
Do they charge more just for the APK installed?!
Has anyone found a way to decrease fan speed or reduce fan noise by doing any external mods e.g. add some kind of mesh or something. Fan noise is particularly annoying if you are trying to watch something on a quarter volume.
Also did anyone found a way to pair bluetooth headphones? I can pair mine, but the sound doesn't come trough.
About £120 at the moment, was £400 yesterday as the Chinese version was reduced to £1100.
