Xenium SP.ice for XBOX
Discussion in 'Xbox Forums' started by Johnny Thunder, Mar 18, 2005.
  1. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I have just installed this chip. All went well, got all LED's that I
    should have got.........put back together and powered up, and
    I am just getting lots of lines across my display.
    Does this mean that one of the gold wires has come loose.....????
    Johnny.
  2. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    An update.........
    I have opened it back up to check, and I still have all good connections.
    Retried on display and still the same. Lots of messed up lines and flickering
    screen.
    Please help guys........... :rolleyes: :lease:
    Johnny.
  3. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
  4. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Forgot to add that it is nothing to do with the chip, it will be to do with the settings/cables/display.
  5. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Thanks for all your help EL.
    THIS is what it looks like, but it is also flickering.
    Johnny.
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Crikey! What input are you using? Component? Have you tried using composite/svideo? That seems like the screen doesnt recognise the signal correctly, there will probably be an option somewhere in the settings. I had a projector once that displayed that with my xbox but never got round to fixing it because it was a loan unit.
  7. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I have it set up component(hidef kit) through my 3805.
    Then component to my display from the 3805.
    This is how it was before the mod.
    Johnny.
  8. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Presumably you dont get a display at all then? Go back to composite and see if you get a picture again?
  9. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Could it be a setting on my display.
  10. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I have connected composite direct to my display and I now have
    a Xenium menu screen.
    Do I have to do something to make everything function via component.
    Thanks.
    Johnny.
  11. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    You have to set the Xbox to NTSC mode using Enighma video switcher, then go into the Video Settings on the MS dash and set the hi-def modes to on m8, then it should be ok, do you have the MS Hi-Def kit or a 3rd party one ?
    Taz
  12. blitzed
    blitzed
    Mar 14, 2005
    386
    28
    hayes
    +43
    looks like resolution is up to high.
    if u can boot to ms dash disable 1080i and 720i then reboot in settings
    ed
  13. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    While in composite, select EEPROM settings and change the region to NTSC. Then try again with component and see what happens? If you still dont get anything then you will have to go back to composite again and sort out chaging the Hi-Def options without MSDash (which I believe can be done with AVALaunch).
  14. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    In eeprom settings, do I change
    Video Standard, or Game Region....?
    Cheers.
  15. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Success..............I am now running through component.
    How do I now get from the Xenium menu to the MS dash
    and vice versa..........
    Thanks guys.
    Johnny.
  16. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    :thumbsup:
    Got everything sorted.............so far.
    I can now play my game.
    When I alter the video settings and activate 480p, 720p
    and 1080i, I end up with a little box in the middle of the display,
    so I have turned the settings back off.
    What do I have to do to put that right.
    Cheers everyone.
    Johnny.
  17. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    Hi m8, which component kit do you have, the MS one or a 3rd party, (I use the MS ver on a m8s, waiting for mine to turn up from ebay) and it works fine, it will go into 4:3 mode if you are playing a 4:3 game, is this what you mean by box in the middle,
    What TV are you connecting it to, does it support Hi-Def upto 1080i ?
    Only certain games from the US are Hi-Def compatible, Soul Calibur is 720p 4:3 not W/S Enter The Matrix is 1080i W/S
    Taz
  18. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I am using official hidef pack from liksang.
    Display is pioneer pdp50mxe-1.
    The picture is in 4:3 mode, but it is in a box in the middle of the screen with
    grey borders on all 4 sides.
    I suspect a setting on the display.
    Johnny.
  19. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Yes I can confirm that is a setting on the display. If the xbox is outputting Hi-def then try setting the display to ensure it is displaying widescreen (auto setting perhaps).
  20. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Solved that one......... :thumbsup:
    It was defaulting to a "Dot by Dot" setting.
    I removed that and it has gone full screen.
    I now have another problem............... :rotfl:
    The picture is now GREEN.......... :confused:
    Will this ever end.
    Johnny.
  21. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Lol oh dear oh dear!
    How green is it? Can you remove the effect with some changes in the plasma settings?
  22. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    This is just pure green.
    The whole thing is made up of green and black.
    :suicide:
  23. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Wow that really is bizarre. Can you try a different cable? Its just about the only thing I can think of at the moment, Im so sorry youve had so many problems with it, it is normally a very simple modification.
  24. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    EL, I have tried various combinations of cables, no joy.
    When I turn off hidef settings, colour is fine etc. etc.
    Anyone got any ideas............................................
    Next step will be the Timpsons............ ;)
    Johnny.
  25. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    This is what is happening.
    When I have activated the hidef settings, I am only getting
    a signal on the green cable. I can actually disconnect the
    Red and Blue cables with no effect whatsoever.
    Please help guys. Is there a setting that I am missing????
    I get all colours output when I deactivate hidef settings......
    Johnny. :lease:
  26. Taz69
    Taz69
    Apr 15, 2002
    3,483
    Bristol
    +357
    Have you set the box to NTSC using Enighma and then set the hidef options using MS dash ?
    It should be fine if you have done this.
    Maybe worth chacking the MS Hidef kit on another xbox to see if thats working ok.
    Taz
  27. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    I have set to ntsc using the control panel of the chip.
    Then sorted hidef settings in msdash.
    Could the hidef kit be dodgy...??????
    It works fine without the settings activated.
    Johnny.
  28. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    It sounds very possible that the hidef kit is dodgy. If possible try and buy one from a highstreet - check it - and give it back to them so they dont know it has been used.
    Alternatively email Lik-Sang and tell them it is broken and I am sure they will be able to help. You shouldnt need to pay for shipping or any of that malarky, dont let them force you to pay for postage.
  29. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Jonny it sounds like your plasma's component input could be set to RGB/VGA. Check in your plasma screen's setup menu that it's set to YPbPr component rather than RGB.
  30. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Nice one mate..............
    I didnt realise, but after selecting hidef settings, I was given another option in the screen setup menu, that is not normally there....(noob)......
    I must say, it has been a chew, but well worth it. picture quality is excellent.
    Thanks for all your help guys, especially Explicitlyrics............ :thumbsup:
    Johnny.
