Hi all,
Thought I'd tell you a quicker way to get a cheap XE1. Only works if you live near a Richer sounds. I got them to beat online price today (the first XE1 they'd received that morning!) paid £456 and they knocked 25 quid off a 3m IXOS HDMI cable!
Generally pleased, not noticed lip sync put definitely have low base on analog.
Now reading the posts it seems this isn't a bug, but a standard for Dolby and to get around you should up the LFE on the amp +10db or reduced all channels (apart from LFE) on the XE1 -10db. Is this true?
I don't think I have firmware 1.3 is there a way to tell - I can't really connect the player to the net. Should I upgrade or leave it alone? I have had a few quirks like disks freezing on loading but each time power off then on again sorts.
