pythagoras
I have on order an XE1, hopefully should be here for the weekend, I have a few queries regarding the best way to connect this up.
I will be using the 5.1 analogue outs, but not sure what type of connection cables I would need to go from the xe1 to the denon 3802
The subwoofer is a rel q-bass which at the minute is connected via left and right front channel, is it better for movies to use a dedicated .1 output on the amp?
And finally
I would like a recommendation for a decent, not necessarily high end, hdmi switch as the xe1 takes my hdmi count to 3 and I only have two on the TV.
Thanks in advance for any help offered,
John.
And finally
John.
