We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Xda IIi - bluetooth connection problem
Discussion in 'Mobile Phones Forum' started by Mad Mikeyboy, Nov 2, 2005.
  1. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    I only wanted a plain old phone but my new company has decided to give me one of these.
    Not much of a tech-head when it comes to these things but I've had a bit of a problem connecting to my bluetooth head set. I seem to be able to pair them up no problem, which it does and creates a shortcut to the device, but whenever I try to connect I just get a connection failed message.
    I've paired it up with other phones and transfered files etc. It justs seems to be the headset which I have problems with. I should also explain the headset works fine with my other phone.....oh and its a Motorola HS820 headset.
    Any help appreciated.
  2. maxima
    maxima
    Apr 16, 2005
    276
    London
    +6
    check the bluetooth versions. if it is the same on both - call O2 support. You will get the proper explanation - why it will never work together :):):)
