XDA IIi battery problem
Discussion in 'Mobile Phones Forum' started by Dog with 3 legs, Feb 27, 2005.
  1. Dog with 3 legs
    Dog with 3 legs
    I've just noticed that if I take the main battery out even for only a few seconds, the machine perfors in effect a hard reset, losing all the data etc.
    I thought the purpose of the backup battery was to prevent this.
    The backup battery is showing 100%.
  2. Neil54
    Neil54
    Jan 17, 2004
    14
    4
    Harlow, Essex, UK
    The backup batteries in the XDA II series are notoriously unreliable. As this is a new device, I'd suggest returning it as faulty! The backup should last at least 30minutes.
    For more quetions/answers on all XDA's and pocket PC's, have you tried the Tekguru forums?
    I'm biased, being one of the moderators, but it is a very useful site, and has taken me from XDA I, through XDA II to my new XDA IIi!
  3. Dog with 3 legs
    Dog with 3 legs
    Many thanks for this. I thought I had solved the problem when I realised I was only turning the PDA part off and not putting it into flight mode.
    I am in 2 minds whether to return it just because I have found it to be so "buggy" (is that a word?)
    I drove a 400 mile trip yesterday and Tomtom crashed a dozen times, bluetooth handsfree is a little hit and miss together with the phone application appearing to be a sophisticated as some of the early brick like mobiles of the 80's.
    Having said that, when it works it works well, it has a fantastic screen and is a true all in one solution.
    My concern in returning it for an exchange is that I will run out of time to cancel th contract I bought it with.
  4. Neil54
    Neil54
    Jan 17, 2004
    14
    4
    Harlow, Essex, UK
    It is a dilemma, but I think your device must be faulty. My XDA IIi has been rock solid, even with TomTom and a BT Headset, though some Today screen switching has caused a few lock-ups.
  5. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    apparently TomTom crashing on long journeys is usually down to the heavy usage of the SD card causing I/O errors. usually a sign of an Iffy SD card, suggest sending it back and getting a better SD card mate.
    Used TomTom now for some time with no issues at all on my card
  6. matblack
    matblack
    Jul 30, 2003
    406
    +10
    There seems to be an issue with the backup battery if you do not open the clip at the bottom fully before you take the main battery out. Somone told me that there is a contact in the clip and if it isn't fully disengaged the backup doesn't kick in.
    So make sure you release the clip all the way before you remove the big battery
    MB
  7. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    O2 have now posted the updated XDA2s ROM on the XDA website (www.my-xda.com)
    According to the blurb it fixes some issues with BT and power management etc..
