Xda 2
Discussion in 'Mobile Phones Forum' started by Doublespresso, Jan 2, 2004.
  1. Doublespresso
    Doublespresso
    Dec 8, 2003
    59
    9
    London
    I'm considering getting an XDA2 on an O2 contract at around £180(400min Xnet @ £45)
    The thing is I thought that it was WiFi enabled so that I could surf on my WiFi LAN, but then I found out that it's an optional thing.. What do I need to add/buy for this? :confused:
    Also can I use it as a SatNav with a Tom Tom/Navman? :confused:
    Anyone has any experience with this PDA would care to comment?
    ...am I better off with a P900 which is currently free on a similar package on Orange (at the Link).. <tempting>
    Thanks!
    Doublespresso :smashin:
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    For Wireless LAN you need a WiFi SD card (no idea of the price) O2 have screwed up the compatibility with TomTom etc. and are working on a fix (although they blame the other party so it could take a while :rolleyes: ) You might want to wait for the Siemens SX1 before shelling out for the P900.
    Hope this helps. ;)
  3. Sprout Crumble
    Sprout Crumble
    Dec 26, 2001
    228
    +5
    Can't see the Siemens being a better phone to be honest. Its been so long coming to market its beginning to look a little less impressive than it should have been against the P800
  4. Doublespresso
    Doublespresso
    Dec 8, 2003
    59
    9
    London
    thanks rct, it certainly helped... I was about to sign up to O2 but if I can't use TomTom with it... I'd rather wait!
    BTW I checked the WiFi SD card and the cheapest I found was £110 at expansys.
    http://www.expansys.com/product.asp?code=106495
    Doublespresso
