XCard-Component and Radeon DVI
Discussion in 'Desktop & Laptop Computers Forum' started by cwinson, Oct 8, 2003.
  1. cwinson
    cwinson
    Nov 11, 2002
    75
    London
    I currently use a Radeon 9600 in my HTPC, with DVI connection to my projector and S-Video (TV) connection to my TV. I use the ATI video drivers to hot-key switch between primary and secondary monitors as required. All works fine, but....
    I am lookling at getting a new TV with component-in (progressive PAL and NTSC), and would like to know how best to connect up my HTPC using component video.
    I am assuming I need an X-Card (or equivalent) to do this, but I'm not sure how the PC will handle the 2 video cards. (new card for component and Radeon 9600 for DVI)
    Has anyone done this before ?
    Is it possible to do what I'm suggesting ?
    Are the any gotchas I need to be aware of ?
    Chris
  2. onewingedangel
    onewingedangel
    Sep 9, 2003
    417
    +24
    You can get an adapter cable for radeons that let you output component to rca connections, however they may only be avaliable in dvi>component rca form as opposed to vga>component rca. You could then use the radeon for both the primary and secondary display.
  3. Totalnoobee
    Totalnoobee
    The XCard is not a graphics card like the ATI, in fact unless you do a special conection passing the vga output through it before conecting it to a display you won't be able to see its output on your PC monitor.
    It is designed for TV, not PC, so there is no problem whatsoever having both at the same time.
    I have an ATI 9700Pro and the XCard and never had any problem.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    I also have an XCard and a Radeon living happily together in my HTPC with no problems,and use the Radeon as the PC's monitor output,and the XCard for the TV.
  5. Totalnoobee
    Totalnoobee
    Alexs2,
    Have you tried the Xcard scaling? if so, does it look much better than standard 576p? and wich one is best 720p or 1080i?
  6. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    I haven't,as the RPTV I have is not an HDTV compatible set,and actually looks very good using component video from the Xcard...certainly at least as good as most DVD player's I've seen in terms of quality.
