XBR65X900B (open Box) or XBR70X850B
Discussion in 'What Is The Best TV For You?' started by sgterik, Jun 23, 2015.
  1. sgterik
    sgterik
    Jun 23, 2015
    4
    Cave Creek AZ
    Bought a XBR70X850B this past weekend for $2499 at Best Buy. Found an open box ( Wall Demo unit) of the XBR65X900B that is in perfect shape that is marked down to $1699. Should I stick with the larger 70" in the lesser model or grab the great deal on the 65" with geek quad protection? It would still be $500 less. Please help
  2. desinho
    desinho
    Sep 22, 2014
    1,402
    83
    +373
    Unless you care about quality built-in speakers don't see a reason to swap (both active 3D, VA panels). But that is a big price difference and you get a better set that has glowing reviews (if it doesn't have any issues). Too bad there are no reviews of the 70" X850B but the one on youtube looks pretty good ... Probably worth giving (the swap) a go :cool:, the 'local' dimming feature instead of frame dimming seems to be a contributing factor to PQ as well.
