Xbox360
Discussion in 'Blu-ray & DVD Players & Recorders' started by luke_1983uk, Sep 21, 2005.
  1. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,068
    Essex
    +73
    ive looked around and saw the xbox360 will allow you to watch progressive-scan DVD movies right out of the box do you think the player will upscale?
    im now think that buying one of these is the best thing to connect to my new lcd as not only will it play dvds it will do everything else.
    so do you think the dvd player will be any good?
    here is a link to the xbox360 technical page
    http://www.xbox.com/en-GB/xbox360/factsheet.htm
  2. HSC
    HSC
    Nov 23, 2004
    1,984
    63
    Coventry
    +172
    please check the XBOX360 FAQ sticky in the xbox forum for info....(section 2)
    It should be at least as good as the current xbox - which for a small LCD is fine
