xbox360,toshiba
Discussion in 'Xbox Forums' started by tony_ montana, Sep 1, 2005.
  1. tony_ montana
    tony_ montana
    hi all, just bought a toshiba wl56 32inch lcd hdtv want to connect it to xbox 360 when its out but no component connection on the tv,but i do have a pc input RGB will this give a hd and will i see xbox360 games at 1080i or 720p and if not why has ms gone for component when i thought you could only get hd through hdmi or dvi. :)
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Woah dude, ever heard of punctuation?
    RGB won't give a high defintion image. The only connectors that will are VGA, and component on the x360. Remember that 720p isn't true HD either, and will only show a downscaled picture.
  3. tony_ montana
    tony_ montana
  4. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
    Tony, what conections have you got?
    Do you have DVI in?
    I'm wondering if a VGA to DVI converter would work on your toshiba?
  5. tony_ montana
    tony_ montana
    hi m8 rgbpc,pchdmi,hdmi input. :lease:
  6. Scotty306
    Scotty306
    Dec 7, 2003
    392
    +8
  7. Nick_H
    Nick_H
    May 31, 2005
    175
    +6
    Be carfull. I have a 32WL48 which is a great tv but will only display 1024x768 via the VGA connection. I run the laptop through it. HD is not a problem with this set as it has component.
    Nick
  8. tony_ montana
    tony_ montana
    :thumbsup: yes it is,will i get 1080i
    which is better component or rgb,some people on other forums,say rgb is better,is this true. :suicide:
  9. tony_ montana
    tony_ montana
    this is what i mean with hdtv,ive looked into it and true hd is with a hdmi cable.most hdtv's don't have component on them.
  10. nick501
    nick501
    May 6, 2005
    7,203
    Walsall, West Midlands
    +782
    you get component through the VGA on the tosh wl56's. you have to select YUV on the connection setup menu.
    Apologies if you knew this already.
    I am getting the M$ 360 VGA cable to go with my 27WL56. (I'm hoping that If I tell the 360 I have the Component lead connected it'll let me have 1280 x 720 res through the VGA.)
  11. tony_ montana
    tony_ montana
    thanks m8,i did not know that,where abouts in the settings i don't see that setting yuv. :confused:
  12. nick501
    nick501
    May 6, 2005
    7,203
    +782
    turn tv on, press 'ok' on the remote. then scroll down to 'YUV' I think it's under PC.
    There is a long thread in the LCD section on this forum discussing this.
    Basically, some of the first WL56's were shipped without the YUV option (which is a requirement for the 'HD ready' Label the set carries.) and Toshiba replaced these sets. ( I had to have mine replaced as my original tv did not have it)
  13. bishman
    bishman
    Mar 29, 2001
    4,902
    83
    hertford
    +172
    How is 720P not true hd? The 360 is supposed to outout 720p as standard, where does the downscaling come into it?
  14. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    As I understand it a HD image is 1080p I may be incorrect, but any image at a lower resolution is downscaled from 1080p. Other sets are called "hd ready" which just means that the tv can decrypt a hd resolution signal to 480p I think. But you also get the middle ground at 720p, which although is a hd image it is still not true hd.
    All I really know is that "true" HDTV is a 1080p image.
  15. tony_ montana
    tony_ montana
    :thumbsup: yes thats right,1080i is true hd,720p is hd but the picture quality is't as good.
  16. tony_ montana
    tony_ montana
    don't have that m8,all i've got is pc,hdmi,3s,2s,1,vcr,thats it no yuv,should i phone toshiba.
