I just got an Xbox, and can't manage to get both PC and Xbox connected.
My connection is with Virgin.
The modem I got given by Virgin is a Ambit(if is of any help) wired, with one ethernet door.
I've tried a Netgear ethernet switch, and a Pcline one, but in both cases, it doesn't allow both PC and Xbox to be on at the same time.
If Xbox gets connected first, than Pc won't have the internet, and exactly the other way, if PC is connected first, Xbox live won't connect.
I've heard that I might need a router, but, don't know what to get, and if that would actually solve my problem.
, if you have had the same problem, or know how to solve it, it'd be much appreciated.
thanks
my xbox live tag is : aresw11
thank you again in advance for your help
thanks
