xbox360 no video no sound no r.o.d. no contorller connection
Discussion in 'Xbox Forums' started by livininutah, Jan 9, 2012.
  1. livininutah
    livininutah
    Jan 9, 2012
    3
    Ok, so i have a 2008 xbox360 i've had the cd drive replaced and now it shows no picture no sound and my controller will not connect and there is no Red Ring. The power pack does turn on and only the green power light on the xbox shows....how can i troubleshoot to see what i need to replace?
  2. niall campbell
    niall campbell
    Nov 16, 2007
    1,048
    48
    +66
    if the power pack does not come on must mean the power pack away but baffled why the green light comes on
    once in a blue moon I have to switch my power pack off at the wall to reset it
  3. livininutah
    livininutah
    Jan 9, 2012
    3
    the power pack turns on and green. The controller can turn it on, but it does not connect to the xbox. everything worked well before i had the cd drive replaced. can anyone suggest a way to test this to isolate what the issue is?
  4. niall campbell
    niall campbell
    Nov 16, 2007
    1,048
    48
    +66
    have you tried syncing the remote back to the xbox ?
    have you made sure cables in tight in the back and tried on another tv
  5. livininutah
    livininutah
    Jan 9, 2012
    3
    I have tried but I dont get no other green lights just the middle green light. I can hear it reading my disk but thats all its doing....
  6. niall campbell
    niall campbell
    Nov 16, 2007
    1,048
    48
    +66
    not looking good
    phone up xbox support. with £160 for a 250 gb model , it might be cheaper getting a new quieter one
    and install games to hard drive to stop cd wearing out
