Xbox360 - No Sound on Streaming HiDef .ts files
Discussion in 'Xbox Forums' started by nmacog, Dec 21, 2006.
  1. nmacog
    nmacog
    Jun 21, 2004
    69
    London
    +7
    Hi all,
    I just got an Xbox360 a few days ago and have managed to get streaming wmv from a Windows XP Professional machine to the 360 with no problems.
    However I tried streaming high definition .ts (transport stream) files from a Windows XP Media Center machine and I can see the video just fine but no sound on ANY of the .ts files.
    Any ideas ? I have loaded XP Media Center codecs and the K-Lite codec pack on XP Media Center
    Does anyone know how to stream divx/mkv/mp4 files from an XP machine without having to transcode ?
    Thanks in advance
    Merry Xmas to you all
    SS
  2. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    I belive it only supports wmv files. Transcode is the only way around it.
    Unless Microsoft do something shortly to fix it.
  3. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    There's already a thread about the ts file sound problem, with the soultion.
  4. leef1234
    leef1234
    May 4, 2005
    600
    +17
    Transcode is your only option for the latter file types you mention.
    Did you install HDTVPump to get the ts files to stream? If you did try uninstalling it the installing it again, worked for me.
  5. jamo9000
    jamo9000
    Nov 29, 2006
    124
    +8
    oooo just what i need.
    I have xp pro not the media center edition, is it this os that your using to stream vids to the 360, I thought i can only see pics and play music from my pc.
    I thought you needed media center to take advantage of streaming vids and watchin tv.
    Please if it is poss to stream vids and do more that just pics and music please a little explination or a point in the right direction would be very much appreciated
  6. nmacog
    nmacog
    Jun 21, 2004
    69
    London
    +7
    Hi smokedog - do you have the URL to the thread on the sound problem with .ts ?
    thanks mate
  7. Steve1987
    Steve1987
    Nov 22, 2006
    11
    +6
    If you rename the .ts extension to .mpg it will play fine. I'm not sure if it reduces the quality but looks good enough to me.
    jamo9000 you can now stream wmv to your 360 via XP. It was included in one of the recent updates. But I use Media Centre so I'm not sure how it works.
    You might need to update the program your using at the moment to share pics and music.
  8. nmacog
    nmacog
    Jun 21, 2004
    69
    London
    +7
    Hey Steve1987
    I'll try that later - many thanks for your help
    SS
  9. calibos
    calibos
    Aug 4, 2000
    955
    Ireland
    +40
    Did you install AC3filter?
  10. nmacog
    nmacog
    Jun 21, 2004
    69
    London
    +7
    Hi guys
    I tried renaming the files to .mpg and also installed the AC3 codec - still not working
    Any other ideas ?
    wmv play sound fine
    thanks
    SS
  11. Steve1987
    Steve1987
    Nov 22, 2006
    11
    +6
    Hi mate
    I've just tried to play a .ts file and your right there is no sound!
    It used to work fine for me, so it's either down to me not having the correct codec installed or because I'm no longer using the digital out.
    I've got HD pump installed, and the files play fine on the pc. I don't get what I'm missing. Does the 360 output .ts files in stereo?
  12. kevlar
    kevlar
    Nov 7, 2005
    1,730
    +103
    I get full 5.1 audio from my .TS files via 360.
  13. mik
    mik
    Dec 11, 2002
    148
    +10
    I have had the no sound a few times, always when I install codec packs. I would uninstall the k-lite pack (haali media splitter gives problems) and just install powerdvd, if already installed do it again and you should be ok
  14. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    MAke sure ithe audio isn't DTS as it wouldn't work.
