Xbox360 looks bad on Panny 42 Plasma with scart
Discussion in 'Xbox Forums' started by jakester, Mar 19, 2006.
  1. jakester
    jakester
    Mar 6, 2005
    41
    London
    For some reason, when I plug the Xbox360 into throght the SCART on my TH-42PE30B the picture looks awful.
    The green part of the display looks all grainy and almost grey!! I tried using the three cables that go into the scart adaptor but that isnt much better. I can use the component cable fine with great results but my HD/DVD Recorder was using that - I really dont wanna be fidling around behind the telly every time I wanna use the other piece of kit.
    Any advice?
  2. SagaLout
    SagaLout
    Jun 7, 2001
    343
    +17
    does it not have a VGA socket? You seriously dont want to be using scart into a plasma. Whilst it wont look as bad as scart into LCD it wont be a patch on component or VGA - plus it sounds like you are using the half scart that comes with the 360, which is actually just composite. If you dont have a VGA socket you might want to get a component splitter.
  3. sdb123
    sdb123
    May 17, 2005
    18,183
    2
    Rushden, Northants
    +2,255
    Are you using RGB Scart? Have you changed the XBox 360 display settings when using the Scart connection?
  4. petekv32
    petekv32
    Dec 12, 2002
    174
    +20
    JS tech master component switcher is great I have one for the same (nearly pw6) plasma. Two component input-> one out
    Do a search for other opinions
    www.js-technology.com
    Several users use his kit. seems very good.
  5. jakester
    jakester
    Mar 6, 2005
    41
    London
    Cheers guys. I was using the half scart thing at first before I started fiddling with my components.
    I have read of a converter for older plasmas to enable them to take a HDMI signal so Ill get a VGA cable to link that up to my telly.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    its your plasma thats the culprit and you will struggle besst bet is component 1080i output from Xbox 360 PE30 wont take 720p
