Xbox360 + LCD TV + Projector
Discussion in 'Xbox Forums' started by buba, Mar 28, 2006.
  1. buba
    buba
    Dec 14, 2002
    118
    +5
    I need help with working out how I can share the component out from my XBOX360.
    I need to be able to get the picture on to the Projector and LCD TV (looking to buy now).
    Currently I have component cables going from my DVD player and Xbox360 to my amp. Then the monitor feed goes to the projector.
    Cheers:thumbsup:
  2. BruceH
    BruceH
    Dec 29, 2004
    260
    Weston-super-Mare
    +9
    I have this setup but it's not ideal.
    effectively i have the composite feed to the tv and the component feed to the projector.
    i have to switch the lead manually which reboots the xbox so not ideal.
    this whole lot is switched throught a denon 4306.
    problem is that the 4306 cant downscale the hd component to composite.
    if you figure it out I'd love to know.
    cheers,
    Bruce.
  3. buba
    buba
    Dec 14, 2002
    118
    +5
  4. emporer
    emporer
    Mar 10, 2005
    8,236
    +1,626
    i use a jstech component buffer to provide 2 outputs from 1 input, works a charm on my panny plasma and panny pj
  5. buba
    buba
    Dec 14, 2002
    118
    +5
    Whats a jstech component buffer?
  6. buba
    buba
    Dec 14, 2002
    118
    +5
    Panic over... found it!
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,199
    +1,241
    Same here.
  8. buba
    buba
    Dec 14, 2002
    118
    +5
    J.S Technology
    Active COMPONENT Buffer
    Two fully buffered outputs, no loss in brightness.
    Looks like the one to go for:smashin:
    Cheers folks
