xbox360 help
pitchin4eva
Doe's anyone have any info on how to connect my xbox360 & pc to one monitor
eg. switch box etc.
Is this possible?
Any links would be great.
A
applevenus
you have two choices :
1. get a monitor switch
or
2. if you have a monitor with multiple inputs you can put the 360 on one input and your PC on the other (that's the way I have mine setup : VGA from the 360 and DVI from the PC) and I just use the switch on the front of the monitor (this one from Dell :http://accessories.euro.dell.com/sna/ProductDetail.aspx?sku=29082&c=ie&category_id=6198&cs=iedhs1&image_flag=True&l=en&s=dhs&show_summary=False&page=productlisting.aspx ) which has separate composite & s-video inputs, DVI and VGA inputs. You can switch between them on the front panel.
Overlord69
Trending threads
