xbox xlink wireless issues, help!!
Discussion in 'Xbox Forums' started by sirp, Sep 2, 2004.
  1. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    ok, im trying to get two XBOX talking to each other over LAN..just need bit more help
    setup is as follows:
    D-LINK 624 router
    NTL modem in Router
    Wireless connection from PC to router
    XBOX 1 wired (crossover cable) to PC so shares connection
    that all works hunky dorey, i internet connection share/bridge to get on LIVE
    XBOX 2 connected to LINKSYS bridge WET54G (ip of bridge 192.168.0.110) using cat5 cable
    that connects to live no problem too
    now i want to get these bricks talking for system llink
    if i set up a server on XBOX 2, XBOX 1 can see the game server, but will not connect, and vice versa
    im assuming i need to port forward something or similar on my 624 router, but not sure what exactly to do; im assuming my router is stopping the XBOX accessing my PC. now i have also updated my firmware today to see if that helps..did it eck!! it screwed my live connections as they added a new dns option to the firmware..but sorted that out..but still cannot get these buggers to talk!
    ips are assigned by router...192.168.0.1/2/3/4 etc
    by the way, connections are set to infrastructure.
    any help? :lease:
    cheers
