Xbox worth it for my needs?
Discussion in 'Desktop & Laptop Computers Forum' started by doctorjuggles, Apr 13, 2005.
  1. doctorjuggles
    doctorjuggles
    Aug 31, 2004
    799
    London
    +19
    Ultimately I'll be building myself a Home Theatre PC sometime in the future, but in the meantime, my copmany is selling off some of our old Xboxes to staff for £45.
    I'm wondering if I should go for it and buy one to use as a networked modded home theatre server in the mean time, or should I just save my £45 and put it toward the HTPC when the time comes to build it?
    Remember that this console will be feeding into a 42" plasma, (non hi-def compatible,) so it'll need to be able to scale well enough to drive the plasma to a decent level, otherwise it's just a waste of £45. But it's a tempting prospect at that price, so advice on this is most welcome.
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    $64,000 question really. I suppose the problem comes where you define "well enough". I started out with a chipped xbox feeding my 36" CRT via component and found the pic quality to be acceptable. I think for £45 you could give it a go, you could always ebay the xbox if you don't like it.
