xbox won't work on my plasma (help)
Discussion in 'Plasma TVs' started by bert_ryan, Jan 3, 2005.
  1. bert_ryan
    bert_ryan
    Hi people im in need of some advice
    I have a panasonic TH-42PWD6 with a component board running to a denon 2900 my sky box runs in to a js tech rgb/vga convertor and works fine, but when i try my xbox in to the js tech box i get a black srceen no picture at all.
    I have tried changing all the settings on the plasma but i still can't get a picture.
    can anyone help (PLEASE)
    :suicide:
  2. Stephen Wilde
    Stephen Wilde
    Nov 15, 2003
    1,810
    48
    +93
    Your x Box is not sending out an RGB signal. Try using one of the other inputs such as direct to VGA without using the converter or DVI if you have it.
  3. Evil Engineer
    Evil Engineer
    Nov 13, 2004
    994
    South of Heaven
    +61
    What type of lead are you using from the Xbox ?
    You'll nead a propper fully wired RGB Scart lead like the official Microsoft "Advanced Scart" which also has the advantage of an optical output for dolby digital (Other cheaper alternatives are available).
    The standard lead (with three phonos plugged into a Scart adaptor) is composite only and won't work.
    Alternatively you could get a Component lead from your local GAME and bypass the JS-Tech totally.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the MS advanced AV cable (RGB scart output) and run this into VCR scart on sky box so when XBOX is on and sky off Xbox will appear on screen (get the cabe it works perfectly........)
  5. bert_ryan
    bert_ryan
    Thanks people at last i can play on big srceen :thumbsup:
  6. Stephen Wilde
    Stephen Wilde
    Nov 15, 2003
    1,810
    48
    +93
    Which solution did the trick?
