XBox via Lan problem
towser
Hopefully some kind soul can shed some light on my problem.
I have a Thompson router (supplied by BeThere) and various items connected both wirelessly and via lan cable.
Now Yesterday I purchased a NetGear GS605 5-Port Gigabit Ethernet Switch, I connected this to my router and XBox 360 with straight ethernet cables, but the XBox would not connect to the internet, so I removed the GS605 and connected direct with the cable, still nothing.
I tested the cable and it works fine when plugged into my BD player and my Technomate Sat receiver.
Can anyone tell me what I am doing wrong.
Thanks in advance
Ron
Kristian
Is this the first time you've tried connecting the Xbox to your network? Has it worked before?
Connecting a switch in the way you've described should just work.
towser
yes, I have it connected with a belkin wireless adaptor and it works fine, just my son drives me mad saying it 'lags' he tells me he connected it once direct with a short lan cable and it worked straight away, the cable I am now trying to use is 30 metre's
Ron
towser
yes the lights on the switch and the router light to say a connection is made but cant get any 'traffic' to pass through the cable.
I have also tried connecting the cable direct without the switch and it is the same, although the cable works on other things as I have checked it.
Ron
mossym
is your xbox set for static ip or dhcp?
towser
Static IP, everything on my network is static IP, I have 12 other items on the network besides the XBox.
Ron
Shugster
If you use the web browser on the router, you can setup that device as a gaming console. The o2/BeThere routers have pre-set configurations for various devices. I recently setup my XBox on one & it worked flawlessly. Unfortunately it was the only thing that worked well on the router, so it's now back in the box only to be used as a crap backup.
towser
Thanks, I already did that as I have had it working whilst connected to a belkin wireless adaptor, its just I can't seem to get it working with a direct connection.
Ron
towser
just bumping this back up just in case someone who hasn't seen it yet can help.
Ron
towser
well I came home from work tonight, plugged everything in exactly as the other night and it worked straight away:clap: at a loss as to why it didnt work previously though.
Ron
