xbox via component
Discussion in 'Plasma TVs Forum' started by lei179, Sep 13, 2004.
  1. lei179
    lei179
    Aug 8, 2004
    611
    +12
    Is there a menu on the xbox to enable higher display rates,ive changed my system to ntsc,but cant see anything to change,is it just a case of the terminal board uprating the display ??
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    u have used the enigma video mode switcher?
    if so go into xbox Dashboard, then to video option, if you have set it to NTSC you should see 480, 720 and 1080 checkboxes.
    check as u wish
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    you need the component cable plugged in first
    before the menu appears in MS dashboard
    (I think)
  4. lei179
    lei179
    Aug 8, 2004
    611
    +12
    Thanks guys,hi def pack is on its way. If i plug scart through js>vga i get a green screen,is this caused by a cheap scart lead from xbox ??
    lei
  5. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    you probably want to read the "xbox high definiton kit" (or similar title) thread over on games consoles forum....
  6. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    Interested to know why this would happen?
    This is going to be the way I connected my xbox to the plasma. (well, via daisy chaining it through my telewest box - but the principal is the same).
    Should I be considering another way?
    ZedZed
