xbox turns off when audio adapter conected
magoolie
The xbox works perfect everytime untill i plug in the audio adapter for my turtle beach x12 headset then the screen goes blue and nothing happens,
when i pull out audio adapter the xbox reloads, i use a technica tv on HDMI cable, the headset use too work untill i did a system update then this new problem started,
does anyone have same problem or have a sollution too this problem ty
magoolie
if the audio adapter is pluged in, with or without headset conected system shuts down, how doo i reset resolution settings on xbox
virtual_boy
Start your xbox and hold in the Y and right trigger till the dash comes up, when the xbox restarts it should be set at it's default resolution.
JVC 4K projectors, Denon X3800 & Perlisten speaker reviews, adding a sub to 2-channel + AV/HiFi news
