Xbox toslink sound quality
Discussion in 'Xbox Forums' started by Mr.D, Sep 29, 2003.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    Have my Xbox hooked up to my Yamaha amp via the optical output ( microsoft advanced scart lead ).
    I'm hearing a low level crackle/hum . This is very unusual for a digital connection.
    All other sources are fine so its definitely the Xbox.
    Anyone else experience this?
    I'm pretty sure I don't get the hum when watching a dvd or playing a cd/wma. Only with games.
    The Xbox has an xecuter modchip and a 120Gb HD.
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +850
    maybe the connecter is loose somewhere then.
    Is the cable any good?
  3. ChrisNic
    ChrisNic
    May 11, 2003
    1,895
    63
    Thame
    +108
    My xbox output is great, DD 5.1 is a great feature from them with the right kit. I second the sugestion that it might be a dodgy conection somewhere but does sound very strange for a digital conection, especially optical.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    I'd have thought the connection either works or it doesn't.
    Likewise cable quality ( its a decent cable)
  5. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +850
    i had a strange problem with my decoder, the dolby worked fine, but dts didn't play back. It was a faulty board in the decoder. Try getting that checked out
  6. gunrock
    gunrock
    Apr 3, 2003
    132
    The Burbs, London, UK
    Could it be your optical connection has got dusty or fingerprints on the connectors?
    Gunrock
  7. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    On my Yammy amp, if I enabled any of the fancy DSP modes it messed up the XBox sound.
    I set it to "normal" and it sounds bloody great (still 5.1 digital, of course). Setting it to "enhanced" or one of the DSP settings resulted in weird crackling from the rear speakers.
    My XBox is hooked up via an optical cable BTW
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    DTS works fine.
    I never use the DSP modes with the exception of prologic2.
    I'll have a look at the cable but I really can't see how a digital cable would exhibit a noisy signal : it will either work or not.
  9. ajbm325ic
    ajbm325ic
    Just bought an Xbox and wondered how to connect it to my Yamaha DSPAX620 amp & TV. At the minute i just have the scart going into the TV.
    Thanks,
    Andy
    Sorry to jump onto this question just thought you guys may know.
  10. stigdu
    stigdu
    Mar 23, 2003
    1,833
    Sutton
    +292
    Ditto what he said - I have just the 2 phono leads for audio, but wanted to know if an optical connection straight to my Pioneer amp would sound better, and if so, where would I get one?
  11. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    Well I got the microsoft advance scart from game when I bought the Xbox. Its got a toslink breakout box built into the lead that takes a standard toslink cable.
  12. DazJWood
    DazJWood
    Jun 13, 2002
    176
    19
    Coventry
    I have just bought an XBox and also bought the advanced scart lead from Game.
    I have connected it all up with the optical cable plugging into my Denon 3802. I have configured my amp to input via the optical cable. The sound comes out fine only it doesn't come out in Dolby Digital!? It just displays Pro Logic II.
    I have two games: Soul Reaver II and Colin McCrae II which both have Dolby Digital Sound. I have tried all the settin I can think of on my Amp but it still just comes out as PL II.
    Do I need to set anything up on the XBox somehow to output DD?
    I am new to this console lark so it could be me
    Anyone any ideas?
    Thanks,
    Daz
  13. Mr.D
    Mr.D
    Jul 14, 2000
    11,135
    +1,179
    You need to enable the relevant settings in the Xbox audio menu.
  14. DazJWood
    DazJWood
    Jun 13, 2002
    176
    19
    Coventry
    Thanks!! I have done this! great stuff! the xbox manual is awful
