Xbox & Tosh 36zp38 red smearing
Discussion in 'Xbox Forums' started by Fergal, Jun 8, 2004.
  1. Fergal
    Fergal
    May 21, 2004
    12
    I have my xbox connected via RGB (cheapo cable) and I've noticed red smearing happening on some games. It is particularly noticable on the red cones in PGR2 cone challenges. My xbox is modded and I've switched it to NTSC mode with the Enigmah switcher. Is NTSC mode likely to be causing this problem? Anybody else experienced this? I'm waiting for my HDTV component cables to arrive so I can use prog scan mode. Hopefully this will fix it.
  2. anephric
    anephric
    Mar 23, 2002
    1,048
    Derby
    +147
    I have the same setup, but use the Official Microsoft HDTV kit, and have noticed no such smearing (when you run in progressive).
    'Tis probably your manky cables, m8.... Alternatively, your contrast might be up waaaayyyy too high.
    regards,
    anephric
  3. Spoonman2
    Spoonman2
    Dec 28, 2002
    3,313
    107
    Ashford, Kent
    +460
    I use the official Microsoft component leads, and runs lovely in progressive on my uk machine, with a bit of fiddling of course :)
    Have a Tosh` 32zd26p myself
    Spoony.
