Xbox to projector help
Discussion in 'Xbox Forums' started by hunter_, Apr 6, 2005.
  1. hunter_
    hunter_
    Guys
    Need some help & advice please. I have an Epson TW10, which I love, and currently play the Xbox (PAL) through it using the standard video cables. The picture is not great. I do not want to Mod the Xbox so is there anything else I can do to improve the picture.
    I have tried to search the forums on this but can't seem to find the right search results
  2. John
    John
    Dec 13, 2002
    11,194
    +2,828
    Could try an Svid connector , or even go for RGB scart thru a JS box of Component or VGA flavours . The latter option is going to cost about £150 tho.
    Any reason why you don't want to mod? even a soft one ?
    John
  3. hunter_
    hunter_
    I am mainly worried about getting it wrong and ruining my Xbox!
    What soft mods are there and what would I gain by using them?
  4. John
    John
    Dec 13, 2002
    11,194
    +2,828
    Try a search for "soft mod" . There was a big thread on it , not so long ago .don't know too much about soft modding , I went the chip(hardmod) route with a solderless adapter / slayer auto install .I was worried about screwing my XB as well , but it went relitivly smoothly ;)
    Don't know what your pj is capable of displaying but it will enble you to use Component out from the xbox .
    Good luck
    John
  5. Pooon
    Pooon
    Dec 26, 2002
    7,293
    Canterbury, Kent
    +916
    Soft-Mod is the way to go. The thread that John is refering to was titled "PAL xbox+high-def" and should have all the info in there that you need.
  6. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
