Xbox to Projector help
Discussion in 'Projectors, Screens & Video Processors' started by hunter_, Apr 6, 2005.
  1. hunter_
    hunter_
    Guys
    Need some help & advice please. I have an Epson TW10, which I love, and currently play the Xbox (PAL) through it using the standard video cables. The picture is not great. I do not want to Mod the Xbox so is there anything else I can do to improve the picture.
    I have tried to search the forums on this but can't seem to find the right search results
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Yep buy yourself the MS hidef pack and connect it to your pj with component leads.
    You'll also get an optical out for sound which should improve the sound.
    Have a search in the consoles forum for loads of advice on component leads etc. I bought my lead hidef pack from lik sang can't remeber how much.
  3. hunter_
    hunter_
  4. jumpt_upmunky
    jumpt_upmunky
    Jan 5, 2003
    186
    28
    Hove
    +29
    I have a ptae-100 pj and an xbox, modding the console lets you effectively turn your pal xbox into an ntsc xbox thus enabling progressive scan, which made a massive difference in picture quality for me.
    I did the soft mod on mine, changed the region, and removed the softmod.
