Xbox to PC Monitor Connection???
Discussion in 'Xbox Forums' started by Big_Si, Jun 3, 2005.
  1. Big_Si
    Big_Si
    Apr 26, 2005
    45
    Bolton
    I am wanting to connect my Xbox to my Pc monitor to save room in the spare room. I have had a look at a couple of adapters but am a bit baffled as to what to get and will it work. If i get a basic adapter i suspect i would lose the sound as the sound card is in my PC.
    Is there a way i can put a sort of AV input card into the PC and route it through my PC or is that just bubbles.
    Any advice would be appreciated
  2. Chox1988
    Chox1988
    Mar 30, 2005
    16,821
    basingstoke
    +9,278
    http://www.amazon.com/exec/obidos/ASIN/B00006B8EI/ref=pd_sxp_f/102-6115479-9298512
    This gives u an audio run through so if u have amplified speakers they can be attached to the speaker output on the adaptor. I think it also allows headphones to be directly connected. In our downstairs computer I have an ATI all in one wonder which lets you plug in any console and plays the console straight onto the monitor with sound through the PC's speakers but I run it as the main graphics card, dunno if you'd be willing to do that.
    Hope I've been of help. :)
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,183
    In a secret location with Jennifer Lawrence
    +7,066
