Xbox to Panny plasma problem, help!
Discussion in 'Xbox Forums' started by Syberyan, Nov 22, 2003.
  1. Syberyan
    Syberyan
    I just got a MS high-def component cable to connect my xbox to my panasonic TH-42PHW5 plasma, through the PT600 tuner
    Well, both 480p and 1080i signals work perfectly but I simply can't get 720p to display! I see a screwed up picture for a fraction of a second and then everything goes blank. (same symptom for 720p games or any other xbox app (xbmp, etc ...).
    Does anyone have a similar setup?
    What could be wrong? I'm running out of ideas ...!
  2. dj898
    dj898
    have Hitachi 42" and it doesn 480p/720p/1080i perfectly.
    maybe it's your PPD
    cheers
