Xbox to laptop cable????????
Discussion in 'Xbox Forums' started by I want a plasma, Dec 22, 2004.
  1. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    Hi all,
    can anyone tell me what cable do i need to connect my xbox to a laptop???
    Dont want to play xbox live,just want to be able to play my games using a laptop.
    Cheers,
    Andy.
  2. fozziebear39
    fozziebear39
    Jan 3, 2003
    993
    Newton-le-Willows
    +43
    Yes ?????????? indeed. Ethernet crossover cable will give you Live connection which you dont want. I presume then you want to use your laptop screen? I doubt it has video in so you would need a PCMIA Video Input card but the results would be |*$&(@.
  3. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    yes it does have s-video in port.
    So is that the one i use?????
    If so then i just need an s-video cable yer????
    Andy.
  4. CAS FAN
    CAS FAN
    Nov 24, 2003
    34,622
    167
    The Wheldon Road end!
    +7,829
    are you sure that's S-Video in?? It's common for laptops to have S-Video out (so you can bview it on the telle but never seen an S-Vid in port.
  5. JUS
    JUS
    Jan 21, 2003
    3,163
    Plute
    +212
    You can get a cable for the xbox that has a vga cable box converter thing...so I think you could plug that straight into your laptop???????????????????????????????????????????????????????????????????????????????????????????????????It is very expensive though.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=68262&item=8152826489&rd=1
    Does that help?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????? ? Thought I'd give it a go...loads of ? don't do it for me ;)
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,084
    38
    NW London
    +9
    Unfortunately not, coz i doubt his laptop has a VGA IN either....
    He really would need to get a video in PCMIA card.
