xbox to crt tv + surround sound advice
Discussion in 'Xbox Forums' started by woo88, Jun 10, 2005.
  1. woo88
    woo88
    May 17, 2005
    118
    Hi all.
    I have set up my xbox via the following, but need some advice.
    I have split the the standard scart connection that comes with the xbox into the following:
    The audio via another cable with 2 connectors into my all in one dvd system for surround sound and the video leads straight into the crt tv via the scart adapter that comes with the standard xbox cable.
    Is this the best way of connecting the xbox in order to get 5.1 surround sound and the best picture quality?
    My tv does have component inputs...can I utilise this with the xbox?
    Please help!!!
    Ta.
  2. zAndy1
    zAndy1
    Nov 26, 2002
    21,981
    2
    5
    163
    +8,427
    You won't be getting Dolby Digital 5.1 surround doing it that way, you need to use the optical digital output, does your all in one system have an optical or coaxial digital input at all? At the moment you'll probably be sending dolby surround to your all in one system which isn't a patch on DD 5.1. Yes you can use the component inputs but you probably won't notice much difference over RGB scart (note the RGB there, if it's composite video then you would notice a big difference!) unless you're TV can accept a high def signal and you get your xbox modded in some way so it can output 720p or 1080i in which case you'd be better off using component.
    Andy
